03-26-2024 05:59 AM
Hi my gen 3 thermostat lost connection this morning. Never happened before. Code H71.
I have had this running fine for about 5 months
Followed all the trouble shooting guides a number of times including factory reset and can't connect at all. The manual override works fine.
Currently have the constant yellow light on the heat link.
Can anyone offer any advice?
03-26-2024 06:53 AM - edited 03-26-2024 06:55 AM
You say the yellow light is on the Heat Link, how did you factory reset?
Was the thermostat new or used?
While you are at the H71 screen look at the Tech page, and make a note of the Heat Link, and the 6 digit code. Does that match the code on the Heat Link?
03-29-2024 03:25 AM
Hi thanks...we can close this thread down now as the fault was unfixable (eventually found the thermostat to be faulty) and a replacement ordered.
