10-05-2022 11:03 AM
My thermostat is on and seems to be working and so is my heat link ( showing 3 green lights) but when I adjust the temp on the thermostat or my nest app it doesn’t trigger the boiler so I am having to override the boiler manually for heat and hot water. I’m unsure if it’s a setting or something in equipment which isn’t setup right or if there is a technical issue @
