Heating Issues Problems
MBarry12
Hi
If I turn my heating off at night will it automatically come on at a set time in the morning .?
Because at the moment it doesn’t although you can see the schedule time .
Also do I need to turn off auto schedule to do this ?
Please help .
Thank You
MBarry
CBFox
If you turn the Nest to Off mode, it will not come back on until you turn it to Heat mode.  To have the heat not run at night (or not run much), your schedule should have a set point at bedtime that's set as low as the Nest will let you.  You can either turn off auto-schedule and create your set points manually, or you can let auto-schedule watch the temperatures you choose for a few days.
CBFox
MBarry12
Thank you so much
aatienza
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, CBFox.
Archie
Hello MBarry12,
Hi MBarry12,
I'm checking in to make sure that you've seen our response. If you have any further questions or concerns, please let us know before we lock this thread in 24 hours.
