Heating sync with hot water
Ross8510
Advice required pls - my nest 3rd gen is unable to turn off the heating when the hot water is on. This is despite reaching and exceeding the set temperature. If I manually turn off the hot water on the schedule the heating will then switch off. How can I fix this? My thoughts are that there’s a wiring issue?? 🤷‍♂️ thank you for any help!
0 REPLIES 0
