11-28-2021 12:29 AM
Hello after using my nest thermostat for well over a year it has now decided to stop working.
The heatlink has no power, none of the lights are turning on. There is 240V present on the unit. I have tried resetting the unit and also recycling the power.
How do I go about getting a replacement heatlink
I have tried to contact your help team through the chat and despite it stating your working hours are 12:00 AM-11:59 PM I always get an message "Please try again during support hours."
Thanks
11-30-2021 10:45 AM
Hello @Kasp,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
Cristian
12-10-2021 09:02 AM
Hi, I wanted to check in. Do you need any further assistance?
If so, make sure to let me know.
12-13-2021 05:00 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
