Heatlink problem
jim-grayson
Heatlink has power but no lights and will not work or reset.
How do I organise a warranty replacement?
6 REPLIES 6
CristianC
Hello @jim-grayson,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
Hi
Thanks for your reply.
Spoken to Google and a new Heat Link is supposed to be on its way….
To answer your questions:
No lights at all on HL, 230v ok
Installed 18 months
H71 error on thermostat
Power cut 4 days previously but had worked for 3 1/2 days since
Only 1 zone with single stat
My assumption is that power supply inside HL has failed (post power cut) but by the sound of various threads I read this is a relatively common issue
Cheers
CristianC
Hey @jim-grayson. I'm happy to hear that you've already got a resolution. Let me know if you need any assistance with your replacement.
CristianC
Hello again. Is everything ok with your replacement?
Hi, all good thanks !
Do you know if the replacement HL's are modified in any way to prevent the same problem occurring again ?
AlexD
We don't have any information we can share about the structure of the Heat Link. Rest assured that we're always looking to improve our products and services.
