Help Connecting Nest Thermostat to Network
Faded
So I have a Nest thermostat which was connected to my network fine through my Fritz!Box. However, this weekend I installed some powerline/wi-fi extenders (TL-WPA4220 KIT) and moved my router. Since doing so I can no longer get my Nest Thermostat to connect.
The only way I have solved this is to turn off all security on my router and connect, however as soon as I turn the security back on the Thermostat disconnects.
Any help/advice would be appreciated.
Ryan_G
Hi Faded,
Thanks for reaching out and we're sorry to hear about what's happening.
Based on your descriptions, your Google Nest thermostat is working fine, however, the security protocol on your router is preventing it from connecting successfully.
Check out this link for the complete guides and the compatible settings for your Google Nest thermostat.
Let me know how it goes by replying to this thread.
Ryan
Ryan_G
Hey Faded,
Ryan
Ryan_G
Hope this helps!
Kind regards,
Ryan
