12-20-2021 01:07 PM
Honeywell Wiring Block
Air Handler
Air Handler Wiring Diagram
When I installed the NEST Learning Thermostat I was upgrading from a Honeywell wi-fi smart thermostat where we had to jump the green fan wire to the C terminal on the air handler. Before the install I reattached the green wire to the G terminal (picture 2, G terminal in between the W1 and O terminal). I then connected the Rc and R wires from the Honeywell block to the Rc and Rh terminal on the Nest block respectively. I connected the green wire to the G terminal on the nest block, the W wire to the W1 terminal and the Y wire to the Y1 terminal. The thermostat booted up but only the Cool mode was showing, no other modes. I did not reset the thermostat although it did go thru a set up before I switched over the green wire.
My questions are;
-do I need to reset the thermostat and go thru the set up again?
- do I need a heat link for this thermostat to work
- is there something wrong with the way I'm wiring to the Nest block?
Please advise, I appreciate any help I can get.
PS: I will clean up the wiring connections once I know I'm doing it right 😉
07-20-2022 10:49 AM
In an effort to keep content fresh on the forums here and prioritize current issues, I'm going to go ahead and close up this thread. If you have any outstanding issues from this post or any other problems, please feel free to open up a new discussion.
Jeff
