Help!! Trouble with wire connections
Joevark91
Hello I have a question regarding my current wiring. The original wiring had a green wire in the OB/w1 slot. Where does this go on the nest? I have it in the w1 slot now and the heat does not work when I turn it on.
Thank you.
Post a picture of the original thermostat's wiring here.
MelbaDT
Thanks for responding, Patrick_Caezza.
Joevark91, just dropping by to check if you still need help with this. If yes, do post a photo of your old thermostat wires like Patrick_Caezza is asking above. We'll be glad to check on it further.
Melba
MelbaDT
Checking back in — how's your Nest thermostat now?
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. Should you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
