04-26-2024 02:31 PM - edited 04-28-2024 08:10 AM
Hi! I wanted to exchange my old thermostat with a 3rd gen Nest Smart Thermostat. My system has a heat pump and the following wires:
C, O, B, W/E jumpered to W2, RH jumpered to RC, G, Y.
I already learned not to worry about the RH-RC jumper, that the nest will do that automatically.
Two questions:
What about the W/E-W2 jumper?
What do I do with the O wire?
Thanks for your help!
04-30-2024 10:30 AM
Hi @uelzi74,
Thanks for reaching out to the community! I'm excited to hear you're considering a Nest Thermostat upgrade. I can definitely help with your compatibility. concerns.
To better assist you, I'd like to ask a question:
Please keep me posted.
Jenniffer
