Help on thermostat compatibility!
YuchenXie
Requesting help, I am very interested in purchasing a Nest Thermostat, but I am not sure if it is compatible with my home. It now has seven wires already connected and they are R , W/Y, Y/A, GI, Gm, GH, and C. 
2 Recommended AnswerS
You are compatible with the Nest Learning Thermostat, 3rd Gen
Try this wiring
Blue - R to Rc
Orange - W/Y to W1
Yellow - Y/A to Y1
Red - Gl to G
Green - Gm to Y2 (set as 2nd-speed fan relay)
Black - Gh - to * (set as 3rd-speed fan relay)
White - C to C
MelbaDT
We haven't heard from you in a while so we'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
9 REPLIES 9
Yes, your system is compatible with the Nest Learning THermostat, 3rd Gen.
I can't see the colors of the wires at each terminal. Can you post a picture showing them?
Thank you very much for your reply sir! As shown in the picture Blue-R, Orange-W/Y, Yellow-Y/A, Red-GI, Green-Gm, Black-Gh, White-C.
Try this wiring
Blue - R to Rc
Orange - W/Y to W1
Yellow - Y/A to Y1
Red - Gl to G
White - C to C
Ryan_G
Hi YuchenXie,
Thanks for reaching out here in the community.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. We'll be glad to assist you further if you have any other questions.
Thanks for always helping us, Patrick_Caezza.
Ryan
Ryan_G
Hey YuchenXie,
Ryan
Ryan_G
Have a great day.
Ryan
Ryan_G
Ryan
MelbaDT
Melba
