08-31-2021 01:11 PM
Any advice on how to wire my nest thermostat? I've successfully done a handful but this one I can't seem to make work correctly.
09-05-2021 10:04 AM
It’s physically set up. We just need help trying to do the initial set up in the system and sync it to our phone. We’ve gone through all the steps using the QR code, and the key code and at the end we just get something went wrong.
09-10-2021 10:14 AM
I'm so sorry for the delay in our response, but I wanted to hop in here to make sure we addressed your concern. I can definitely understand the confusion when it comes to thermostat issues as it can be very odd to figure out sometimes, but I'm happy to look into this for you.
First off, I would suggest using the Compatibility Checker to see if your system is compatible. Then, if it is, I would suggest contacting a pro to come out to help you with this since I know that the Nest thermostat is not compatible with stranded wires, every wire has to be connected to the Nest Thermostat system.
Please let me know if you have any further questions or concerns as I'm happy to help.
Garrett DS
09-13-2021 03:43 PM
Have a great day.
Garrett DS
09-13-2021 03:47 PM
I hooked it up myself after a little more research. So far it's working fine. We'll see if it works with the heat in a couple months (it did not my last attempt!)
09-13-2021 03:53 PM
It looks like we have come to a solution so I'm going to be locking this thread. If you have any other concerns or questions, please feel free to create a new thread.
Have a great day.
Garrett DS
