04-25-2023 08:06 PM
Need help installing my nest thermostat with my current thermostat wiring
04-26-2023 04:23 PM
Your current thermostat is only fully compatible with the Nest Learning Thermostat, 3rd Gen.
You would wire it like this
Red - R to Rc
Blue - B to C
Orange - O to OB
Green - G to G
White - W1 to W1
Black - X2 to * (set as emergency heat)
Yellow - Y to Y1
If you can live without the emergency heat function, you can use the Google Nest Thermostat and tape off the black wire to the X2 terminal.
Wire it like this
Red - R to R
Blue - B to C
Orange - O to */OB
Green - G to G
White - W1 to W
Black - X2 to (tape off)
Yellow - Y to Y
04-29-2023 08:26 AM
Thank you! This worked!
05-02-2023 11:52 AM
Hello folks,
Thanks for sharing a wiring guide, @Patrick_Caezza. Big help!
@Spladae, I'm glad to hear that it was sorted out. I hope you've found the answer you're looking for. If you're still in need of assistance, feel free to let us know. Otherwise, I'll lock this thread for 24 hours.
