05-01-2022 10:27 PM
I have a braemer bmq330 ducted heating unit with manual thermostat controller using 2 batteries and 2 cables from heater.
can you please advise if any of the nest thermostats will be compatible to replace existing manual thermostat?
Including image for reference.
06-17-2022 09:12 PM
Hi Ryan,
thank you for your message.
I have finally installed Honeywell programmable thermostat.
Thank you to everybody who shared knowledge and recommendations with me.
05-02-2022 08:56 PM
The problem with ducted units is they usually use a wireless remote to control them which none of the Nest thermostats are compatible with.
If you have a wired thermostat, it might be unless it is using a proprietary interface that is also not compatible.
05-04-2022 01:08 AM
thank you for your reply..
my ducted heating unit does kit have any remote control. It’s a manual thermostat controller which I am trying to replace with programmable thermostat.
05-04-2022 05:33 PM
Post a picture of the original thermostat's wiring here
05-09-2022 05:21 PM
Hi Jesseaxel,
Thanks for reaching out here in the community and for providing a photo of your current thermostat.
I can't really tell if your thermostat has a proprietary system which is not compatible with the Nest thermostat. Could you take another picture or let us know what the wire labels are?
Thank you for your help, Patrick_Caezza.
Ryan
05-09-2022 08:18 PM
Hi Ryan,
the installer told me the wires have no labels as the controller has no polarity. I am not sure what that means in electricity terms
05-10-2022 10:18 PM
Hi Jesseaxel,
Thanks for your reply.
No polarity means you can connect those wires either way. There's no positive or negative polarity that you could use as a guide.
Ryan
06-15-2022 09:07 AM
Ryan
06-17-2022 09:12 PM
Hi Ryan,
06-22-2022 05:59 PM
Hey Jesseaxel,
Appreciate the help and thanks for letting us know. Hope that sheds some light on the issue.
Archie
07-01-2022 04:12 PM
Hey Jesseaxel,
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Archie
05-04-2022 08:42 PM
05-04-2022 08:43 PM
I am told by installer the controller has no polarity. Not sure what it means
06-08-2022 02:32 AM
https://www.youtube.com/watch?v=-MptX7Hou7k&t=463s&ab_channel=Iguana6767
This video did a pretty good job helping me get mine going.
Note that the thermostat itself needs something to keep it going (it has a built in battery but who wants to take it off the wall to charge it) so i installed a https://www.amazon.com.au/gp/product/B0786ZRBFV/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 cut the end of and wired that as my "c" and "rc" cable hope this helps
