03-03-2022 04:54 PM
I need help wiring my Nest
03-03-2022 10:14 PM
Give this wiring a try.
Blue - C to C
Orange - O to OB
Red - RH to Rc (jumper to RC not needed)
Green - G to G
Yellow - Y to Y1 (jumper to W not needed)
03-04-2022 06:10 AM
I tried that but it wont even power on. Any other solutions? I reinstalled the old thermostat and it worked fine.
03-04-2022 12:46 PM
This is how i am wiring it. It won't turn on. When i connect my old thermostat, it turns on
03-12-2022 01:51 PM
Hey epiphini,
I just wanted to follow up and see if you're still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
03-04-2022 12:46 PM
I even bought a new Nest and tried that, not working.
03-15-2022 04:32 PM
Have a great day.
Ryan
03-15-2022 04:35 PM
All set. C wire wasn't connected at the furnace. Thanks.
03-18-2022 05:26 AM
Hi epiphini,
Thanks for the update.
It is great to hear that it is up and running well now. Connecting a C wire would eliminate problems not only with battery but for your HVAC behavior as well.
If you have any other questions, don't hesitate to get back to us and we'll be glad to assist you as this thread will now be locked.
Ryan
03-04-2022 04:54 PM
It would appear you have wired everything as you should. What we don't know is if those wires are in fact connected at the A/C side. Do you know if the old thermostat uses batteries? It's entirely possible the (C)ommon wire (Blue) is not actually connected at the A/C.
