Hot water schedule won’t work in the app
PeteAde
I have a baxi system boiler and baxi hot water cylinder connected to my nest learning thermostat. The hot water schedule opens then immediately closes whenever I tap the schedule button in the app, however, it works fine from the base unit, e.g. I can access the schedule and the cylinder heats the water according to the schedule so know it’s not a compatibility issue. Seems like an app problem.
Can anyone advise why the hot water schedule won’t work in the app?
Vladut
Hi there, thank you so much for reaching out. We're so sorry for any inconvenience caused by this. Can you tell us if the same behavior applies on the web app?
AlexD
Hi, I wanted to check in. Did you see my colleague's message? Make sure to let me know if you need further assistance.
PeteAde
I’ve replied
PeteAde
Hi, I’ve just tried the web app and the hot water schedule is blank
