10-20-2022 11:00 AM
I made some errors in setting up the Next thermostat. Namely, not knowing how to move among the choices (rotating ring). How do I start over, i.e., how do I reset the thermostat to its out-of-box settings and program it right?
Thanks!
10-20-2022 11:05 AM
These are Google Nest's instructions for restarting or resetting a Nest thermostat:
https://support.google.com/googlenest/answer/9247296?hl=en-GB#zippy=
10-25-2022 01:52 PM
Thanks for reaching out. I'd love to help.
@MplsCustomer, thanks for sharing the article on how to reset the thermostat to default.
@design2358, how's your thermostat? Were you able to do the step from the link? I'd be glad to hear from you — I'd like to make sure everything is working.
Keep us posted.
10-28-2022 03:47 PM
Edward
10-31-2022 11:12 AM
Mel
