How to wire Nest E with two wires directly connected with automatic gas valve and transformer?
jitasi
My old thermostat only has 2 wires, one white and one red/white.
The wiring diagram provided by the furnace is as illustrated in the attached photo.
https://photos.app.goo.gl/i1yX9V7XvoebvVsAA
How should I connect the Nest Thermostat E with it?
AxelD
Hi jitasi,
Thanks for posting! I'm happy to help you with this wiring configuration assistance. I have a question about your thermostat:
  • What are the tag letters on the thermostat for each wire? E.g. W and R.
In the case you have W and R or RC/RH. Here you have an image with the recommended wiring:
It's always recommended to have a C-WIRE or a Nest Power Connector because it will provide a stable power source for your Nest thermostat when your system can’t deliver enough consistent power to it.
Axel.
jitasi
I have W and R line.  I also have a nest power connector, but don’t know how to connect it
AxelD
Hi jitasi,
That sounds great! No worries, here you have a video tutorial that explains How to Install a Nest Power Connector for Your Nest Thermostat.
If you have more questions, let me know.
Axel.
