Installing google power connector at control panel
Aadityakiri
I have a 2 zone HVAC system and thus have installed 2 Google nest thermostats. Both were alerting me as to needing a c wire for adequate power supply. Google offers their power connector as a substitute. Now, I have tried to install the power connector at the control panel such that one device will suffice for both zones but I am unclear as to how that may work. I installed the power connector at what appears to be the main system on the control panel, which is an EWC ncm 300 panel, unsuccessful. When I install the power connector to a single zone, that works fine however just for a single zone. Is there a way to use one power connector for both zones or am I stuck needing to get an additional power connector?
No, just like you need to have a separate thermostat for each zone, you will need to have a separate Nest Power Connector for each thermostat. The Nest Power Connector becomes an extension of the Nest Thermostat.
MelbaDT
Thanks for responding, Patrick_Caezza.
Aadityakiri, I hope you've got the answer you're looking for. I also suggest that you check on this link to know more about our Nest Power Connector: https://bit.ly/3z34z2e
Feel free to reply back to this thread should you have more questions in mind.
Melba
MelbaDT
Hey Aadityakiri,
Checking back in should you still need our help.
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
