03-17-2024 04:08 AM
My Nest Thermostat has recently started to go offline. I suspect a hardware fault with the Thermostat.
I have reseated the Thermostat on the Nest stand. The connections look clean.
When I ping the device it will run for a while and then stop with Offline message on Thermostat display. If I move Thermostat with its Stand the ping will automatically start again. I suspect a loose internal connection. Fault occurs while running on mains electricity or the internal battery.
Ping shows "Request timed out" when failing. No other devices are having this problem.
Ping speeds highly variable.
EERO network, Router IPv4 / IPv6
I don't know if it's the Thermostat or stand.
Thermostat on latest Software 5.9.5-2 Display 3.4
Base 2.3.23/3.1 Backplate 6.5
Time Zone GMT UK
How can I arrange replacements? It's Winter here!!!!!
