04-20-2022 05:12 AM - edited 04-20-2022 05:26 AM
I have a 4 wire system with the Honeywell wire saver connection. When I use the Google Nest wire checker it tells me its compatible when I enter the wire codes but I have been told the same thing by the people that make "Sensi" and that ended not working with my system. Can't run the fan on its own (and I need that choice), fan would only run when AC or Heat is activated by system. My wires are R and RC (with a jumper), W/OB, C, and K. See attached pic. Can someone help?
04-20-2022 01:58 PM
You will have to replace the WireSaver with the Nest Power Connector. They do the same thing, but each only works with the specified manufactures' thermostat.
04-26-2022 04:03 PM
Hi ThomasJo,
Thanks for reaching out and we're sorry for the delay.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. We'd love to hear from you on how it's going with your wire configurations.
Ryan
05-09-2022 06:33 PM
Checking back in should you still need our help here. Feel free to reply back to this thread.
Melba
05-10-2022 07:03 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
