Is my cooler controller compatible with Nest thermostat?
Lyddie
Hi, this is a photo of my cooler controller wiring. Is it compatible with Nest thermostat? The label for the two wires are TW1, TW2. The labels below are also TW1 and TW2.IMG_20220907_070542014.jpg
6 REPLIES 6
Jhonleanmel
Hi Lyddie,
Thanks for these added details and I'm sorry for the delay.
I'd love to know more about this. Could you share a photo of your current thermostat's wiring/ control board? What is the make and model of your HVAC system? Also, you could try our compatibility checker to see if your current system is compatible with the Nest Thermostat.
Mel
Hi, I've gone through the compatibility checker already and it sent me on through to this community page. The photo I sent through is all the wiring that there is, at least that'sall that's visible.
Itis a Brivis/Rinnai nc6 I believe.
Jhonleanmel
@Lyddie, thanks for these added details and I'm sorry for the delay.
It seems that you have a proprietary HVAC system which is not compatible with our Nest thermostats. However, we have several users who were able to successfully set up one after rewiring their system. Please contact a pro installer to discuss your options.
Mel
I wanted to check in and see if you managed to see Mel's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
Jeran
Hey there Lyddie,
Did you have any more questions or need any additional help?
Thank you,
Jeran
