12-09-2022 11:51 AM - edited 12-09-2022 01:22 PM
I recently setup 3 temperature sensors. How do you find the label for each sensor if they get mixed up? Do you just have to stick a label on each sensor to keep track of them? I guess you could put one at a time in the freezer to see which temp changes (or take a battery out)?
How do you reinstall them after you've removed and thrown out the QR code after setting it up?
Thanks in advance for the help.
12-14-2022 12:09 PM
I wanted to follow up and see if I could be of any help. I found an article that has more details on the device. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
12-19-2022 06:36 PM
@Mycoal I'm dropping by to ensure that everything is covered here. Were you able to read and check what Jake shared above? In case you have an update, you know where to find us.
I appreciate the help, Jake.
02-08-2023 04:55 PM
No, it doesn’t help. We inadvertently removed the tabs which included the QR codes before realizing they were there and no don’t know which code goes with which scanner. How can we figure this out?
02-14-2023 10:14 AM
Hello robinmwarnerky,
Thanks for reaching out to the Google Nest Community Forum. I'd love to help.
To clarify, are you having trouble adding your Nest Temperature Sensor? If so, setting up the sensor would be done on the Nest app by scanning the QR code. But you will need a Nest Learning Thermostat or a Nest Thermostat E to get it to work. Please have a look at this article and let us know if you need more help.
02-17-2023 10:29 AM
I wanted to check in and see if you managed to see Mark's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
02-19-2023 09:26 AM
Thanks for your help Mark and Jake.
02-19-2023 11:50 AM
I managed to figure this out myself, as there were no solutions to my dilemma online.
For others who may inadvertently remove the battery stickers which contain the QR install codes on them, add each device as 1, 2 and 3. Put them in the fridge one at a time and as the one in the fridge gets cold, you can rename it and put it where you want.
02-19-2023 01:39 PM
Hey robinmwarnerky,
Woohoo! What a great idea. I'm glad that the issue is now resolved. Thank you for the update. It looks like we have come to a solution, so I'm going to lock this thread in 24 hours. If you have any other concerns or questions, please feel free to create a new thread.
12-20-2022 07:07 PM
Hi Mycoal,
Edward
