05-05-2025 02:45 AM
Low battery repeated warnings even after the unit has been plugged in to an external power source for 24 hrs
05-08-2025 06:29 PM
Hello Dakesojo,
Thank you so much for posting in this community. I’m sorry to hear your Nest thermostat's battery is low. Don’t worry; I'd be more than pleased to help.
I appreciate that you have taken action by performing the troubleshooting step above. To gather further details and determine the optimal resolution, could you please help me by answering these questions?
What type of Nest thermostat do you have? For your reference, consult this article: How to tell which Nest thermostat you have.
When did the trouble first occur?
When did you install the thermostat?
Are all the wires of your thermostat seated firmly in its terminals (with no loose or exposed wires)?
Do you see an error code on the thermostat?
Any additional details you can provide will be helpful.
Daniel
