Motion detected display won’t light up when sensing movement on my thermostat
Garydaniels9192
Display won’t wake up when it senses movement in front of it.
Jhonleanmel
Hi Garydaniels9192,
Thanks for posting. You’ll need to be close (typically within 3 feet or about 1 meter) to your Nest thermostat for the display to turn on. However, your Nest thermostat adapts to how much activity there typically is in its location, and it measures the current light level to adjust when exactly it will turn on the display.
Check this link for more details.
Mel
Hey Garydaniels9192,
Mel
Hi Garydaniels9192,
Mel
