My nest thermostat e does not power up after installation
rgaila
 Original Poster: Weldon Hehr
I have reinstalled my old thermostat and it works fine.
rgaila
Hi Weldon,
Sorry to hear about your seemingly dead Nest! I understand how inconvenient that can be for your home. Let's see what's going on with your thermostat.
Here's a guide with possible solutions as to why your thermostat may not be turning on. Typically, if the thermostat is unable to turn on, it usually means that there isn't a consistent power supply (its batteries are low) or incorrect wiring. However, if the reason is not included on this list, we strongly suggest a Nest Pro come out and take a look.
Hope this helps! Let us know if you have any other questions for us.
-From Ai, Community Specialist.
Bilboq998
I need air, i've checked the breaker it is on, but NO life at wall unit!
MelbaDT
Hey Bilboq998,
Sorry for the delayed response here but thanks for reaching out.
What type of Nest thermostat do you have? When did it stop working? Also when you said there is no life at all, is the display not powering on?
Tell me more so I could check on it further.
Melba
MelbaDT
Checking back in — how's it going? Still need our help?
Melba
MelbaDT
Melba
