11-06-2022 01:30 AM
Our Nest thermostat was u plugged for a while so this may be a power issue, but I have had it charging on the base for a couple of days and even tried a different charger cable straight into the back of the thermostat for a few hours now.
The screen is frozen on the white screen with blue nest logo. I have tried manually restarting it by pushing the device in for 10 seconds, releasing then pressing once to activate, but it just returns to the same frozen screen.
Anyone know how I can fix this?
Thanks in advance!
11-09-2022 04:31 PM
Hi SLH,
Thanks for reaching out and I'm sorry to hear that you're still having an issue with your Google Nest Wifi. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Mel
11-12-2022 04:33 PM
Hey SLH,
Checking back in — have you had the chance to fill out the form?
Mel
11-15-2022 04:35 PM
Hi SLH,
I wanted to follow up and see if you are still in need of any help. If so, please fill out the form so we can help you further.
Mel
11-18-2022 04:47 PM
Hi SLH,
Edward
