10-16-2022 12:35 PM
I am having trouble figuring out where to connect the blue wire and the orange wire from my thermostat to the new Nest thermostat. The unit is a heat pump with both heat and cooling, Does the Blue wire go to the Nest C input and the Orange wire go to the Nest OB* input? photos below of current thermostat wiring. Thank you.
10-20-2022 02:30 PM
Chiming in. I'd be happy to take a look into this for you.
I appreciate your help, @Irishjedi.
@ctoles, thanks for posting and letting us know the details of your HVAC system. Based on the wiring diagram from your thermostat, it appears that you have a heat pump type.
You can follow the same wire set up to the Nest thermostat with C (blue), R (red), O/B (orange), W (white), G (green), and Y (yellow). But if you have a Nest Learning Thermostat, move the white wire to the W2/Aux terminal.
Have a look at this article and let us know if you need more help.
10-16-2022 02:32 PM - edited 10-16-2022 02:42 PM
The blue is your Common wire. Put that in C on your thermostat. That will give constant power to the thermo. The orange looks to go into the OB.
10-16-2022 03:54 PM
Thanks for your quick response. I think I should have provided some additional information when i asked for wiring help, I want to make sure I wire the thermostat correctly. I have 2 heating/cooling zones in the house, one for upstairs and another for downstairs. The upstairs unit is a combo heat/cool/emerg heat heat pump unit with a dedicated air handler for this unit. The downstairs system is a gas furnace with an associated cool only heat pump unit and the downstairs has its own dedicated air handler. I am only wiring the nest thermostat for the upstairs heat pump. Considering this additional information, do I still not need the orange wire? It was connected to the 0 terminal with the old thermostat.
10-16-2022 04:38 PM
I only have a heat too and I didn't use the orange. I only used the red, white, and blue. Hope this helps.
10-17-2022 04:39 AM
The "heat pump" that I am wiring the nest thermo for provides cooling and heat. Still not sure if I am supposed to wire the orange to the 0B* slot. Should I try without orange first and see if all works ok, or should I go ahead run the orange to the 0B* ? Thanks for any insight anyone can provide.
10-20-2022 02:30 PM
10-20-2022 04:47 PM
Thanks mark Joseph and irishjedi. I wired as outlined above with orange in OB* slot and blue in C slot snd all things seems to be working fine so far. Thanks for all the help.
10-20-2022 04:55 PM
Hi ctoles,
Awesome! I'm glad to hear that it's working with the wire set up.
It looks like we have come to a solution so I'm going to be locking this thread in 24 hours unless you have additional questions or concerns.
