Need help - Thermostat is offline and I forgot my PIN.
padmanabhang
My thermostat is offline so I cannot use Nest App.
I also forgot my PIN.
How do I reset the thermostat and get it to connect to WIFI?
The WIFI is up and running and other devices can connect. I have restarted the router multiple times to no use.
David_K
If you can't control it using the app anymore, you'll need to reset it using a computer.
  1. Connect the Nest Thermostat display via USB to a computer.
  2. Verify that the Nest Thermostat mounts (appears as an attached drive icon).
  • If the Nest drive will not mount: Restart the thermostat and the computer.
  • If the Nest drive still won't mount: Connect another device to the cable to see if it appears as an installed device.
  • If it doesn't appear, use a different cable/port/computer.
If the Nest drive is successfully showing up on your computer, can you see a technicalinfo.PLIST file? If you get this far let me know and I'll ask a community specialist to assist with next steps, as these can't be shared publicly in the community.
David_K
