Need help with wiring
minhdiep
Hi everyone, I am trying to replace my cor7 thermostart with a new Nest Thermostart. This is the current setup in my cor7:
O/W2/B: Brown wire
G: Green Wire
Y/Y2: Yellow Wire
Rc : Red Wire
C: Blue Wire
My A/C unit is Carrier Sentry 3-Ton 14 SEER R410A Heat Pump (208/230 V 1-Phase)
Please help. Thank you very much
@minhdiep ,
Your wires for the Nest Learning Thermostat will be:
Rc - Red Wire
OB - Brown Wire
Y1 - Yellow Wire
G - Green Wire
C - Blue Wire
AC Cooling Wizard
