Nest 3rd Gen Thermostat not working on heat or cooling
RB7X
Hi Folks,
I just had a Nest Learning 3rd Gen installed in my mom’s house, and the unit is acting strange. It looks like the fan is blowing, but the A/C is buzzing on the outside condenser, trying to kick on, and on the other end, when I try the heat, the furnace kicks on, then stops, then kicks on again and stops. I had an electrician wire the unit, but he must have done it wrong. I attached pics of my old thermostat wiring vs. how it's wired currently with the Nest. Can anyone help me troubleshoot this? Any ideas. I appreciate your help and guidance!
https://photos.app.goo.gl/XURUY2hx9jrR94Lr6 https://photos.app.goo.gl/hRp7zeXEgJE3WjH8A
virnab
Hi RB7X,
Thank you for posting in the community.
I understand you're looking for help with your mom's new Nest Learning Thermostat 3rd gen. I know how concerning it may be when a new installation isn't working as it should, especially with the A/C unit buzzing and the furnace short-cycling. I appreciate you providing the photos; they are very helpful.
To help me get to the bottom of this, please answer the following questions:
  • Does the thermostat screen indicate that it's actively calling for heating or cooling?
  • When was the last time your HVAC system was serviced and cleaned?
  • Is this the first time you're calling for cooling this year?
  • Do you see a power error code on your thermostat?
  • When did you install the thermostat?
  • Could you please send a photo of the physical wiring on the backplate of the thermostat? (You can see the wires by gently pulling the thermostat display off the wall.)
Please keep me posted.
Virna
