12-30-2022 06:02 PM - edited 12-30-2022 06:05 PM
Nest Learning Thermostat
I have had this this thermostat for over a year now. After the rolling blackouts in Tennessee during December 2022, the thermostat would not send a signal to the heat pump valve to switch back to cool air. I am thinking when the power outages happened, it caused the thermostat to short out. However the thermostat did not display any errors. I ended up having to replace the thermostat because the warranty has run out. Nest support said there was no correcting the thermostat and that it would have to be replaced.
Anyone know a solution without replacing the thermostat?
12-30-2022 07:03 PM
Have to test with a multimeter at the outside unit set meter to AC volts not DC.
Test if you get 24-30v AC on the O wire to C wire outside when AC is on.
If no voltage then the possibly the Nest is not sending the power thru the O wire or the O wire is loose or broken at the furnace screw or outside bad connection.
Or the reversing valve coil is open and power is going to it but the solenoid coil is bad so it doesn't switch position. You can test the Ohms reading of the coil with the meter.
Or the coil is good and getting power but the internal valve is stuck and not changing position.
01-02-2023 02:41 PM
Hey Tpobaw95,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
01-02-2023 08:25 PM
Someone on YouTube suggest replacing the Nest Wiring Base. Said that sometimes the O/B port can short out during a surge. I have purchased a new base and will post results once I have them. Thx!
01-03-2023 02:21 PM
Hey Tpobaw95,
Sounds like a plan!
Archie
01-10-2023 04:02 PM
Archie
01-11-2023 02:15 PM
Hello there,
Archie
