01-14-2022 09:28 AM
Hi my Nest heatlink suddenly stopped working , it has no lights and no power. It is less than 1 years old. My electrician said this is quite a common fault with them.. how do I get a replacement quickly please as We have no heat or hot water?
many thanks in advance
01-17-2022 02:46 AM
Hello @chrismilesitsm,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
01-17-2022 04:00 AM
Hi there CristianC - Thanks for the reply - I had already tried these steps, having researched on the forums 🙂 But I can confirm the following:
Also:
Thanks, Chris
01-17-2022 04:09 AM
It is good to hear you tried those steps and thank you for all the provided information. To continue I would like to reach out to you over the email you are using for your forum account, so I can create a case and continue. Would that be ok?
01-17-2022 04:54 AM
Yes please
01-17-2022 05:58 AM
Hi there. I just sent you an email. Feel free to check it out when you have the time.
01-20-2022 06:32 AM
Hello again. Just checking in. Do you still need assistance?
01-26-2022 10:30 AM
Since you didn't reply to my colleague yet, I'll have to lock this thread. If you still need assistance, feel free to open another one.
