Nest Learnig Heat ling for cooling
S1ckness
Hello Members,
I have the bellow configuration:
Heat pump with 300l buffer
Infloor piping with Giacomin thermo electric actuator normaly closed 230v that im trung to comand with the Nest Learnig Thermostat with Heat link , but i have only option for Heating
I wont to use  thisbconfiguration for cooling in the summer
I'm using it now but without  conroling the acuators ,
Please let me know if there is a solution.
Regards
LarisaL
Hi there, thanks for reaching out! The Nest Learning Thermostat, European version, handles only heating and hot water. For cooling, there is the US version.
Many thanks, Larisa
LarisaL
Many thanks, Larisa
LarisaL
Hi there, did you see the message from above?
LarisaL
I haven't heard from you in a while so I'll be locking this thread. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community. Thanks, Larisa.
