08-19-2023 03:57 PM
08-20-2023 09:18 AM
This is great feedback that I'd encourage you to also send directly to Google. You will not receive a response, unless Google need more details from you, however the team are still reading the feedback.
Depending on frequency and length of outage, I have seen other users look at investing in a UPS system so their thermostat and HVAC system remains online during power outages.
08-20-2023 10:21 AM
After talking with support and then escalating to 2nd level support and getting nowhere they did recommend the feedback site you mentioned. This should be a simple problem for them to fix unless the Nest thermostat has some design flaw that prevents a recheck of power after an interuption. Thanks for the reply.
