03-11-2022 04:57 PM
I have a Nest Learning Thermostat, 3rd Generation and a Nest Temperature Sensor, purchased in November. The thermostat was installed by our HVAC tech in early January. The following week, I started to install the Temperature Sensor. Using the Nest App, I added the sensor, scanned the QR code and started the process to connect the sensor. After a few attempts, the sensor was not detected by the thermostat.
Studying some of the solutions, I removed the sensor from the Nest app and removed the battery from the sensor. After about 10 minutes, I reinserted the battery, added the sensor to the app, scanned the QR code and attempted to connect to the thermostat. After a few attempts, I was still not able to connect to the thermostat. I'm at a loss as to the next steps.BTW, on a the attempts to connect to the thermostat, the sensor was 5 feet away. When it's finally installed, it will be about 12 feet from the thermostat.
Any suggestions?
Thanks!
04-17-2022 06:57 PM
Thanks for the information, the house is a vacation place, so we are not there on a permanent basis. A two story home, with the thermostat on the ground floor and the main living area upstairs. Add to that, southern exposure, making the temperature differential 5-7 degrees. Hence, the sensor seemed like the best solution.
Currently, the sensor is paired correctly and all is well. We were there two weeks ago, ready to restart the Nest, which seemed like a good fix. Only problem, the power was out and didn't come back on until after we left. Next week arrives, power is on, ready to restart the Nest and attempt again. I put the battery in the sensor, went through the pairing wizard and presto, it paired right away. I think the power outage caused the Nest to restart and when I paired the sensor, it worked correctly.
Thanks for the assistance.
Steve
04-12-2022 02:04 PM
Did you ever get this figured out? I have the same problem.
04-13-2022 09:17 AM
Nope, still waiting on an answer.
04-13-2022 09:35 AM
I was actually able to fix the issue by doing a restart on the nest itself. Once it did a restart (not a factor reset) it connected seamlessly.
Press your thermostat ring to open the Quick View menu.
Choose Settings Nest settings icon.
Turn the ring to Reset and press to select.
Choose the restart option...after it reboots you should be able to add the sensors.
04-16-2022 04:30 PM
Thanks for the help, LanceNest. The restart option on your thermostat is a great solution. This will refresh the Bluetooth connections between the thermostat and the Nest Temperature Sensors.
Let us know how it goes by replying to this thread.
Ryan
04-17-2022 06:57 PM
Steve
04-18-2022 04:13 AM
Hey SteveV1,
Thanks for the update. It's great to hear that it is working fine now after you have successfully paired your Nest Temperature Sensors. If you have any other questions, let us know by creating a new thread as this will be locked now.
Ryan
