02-09-2024 03:47 PM
I installed a Nest Connect for my Yale lock, and ever since then my Google Temperature Sensor doesn't work. I tried changing the batteries, but it still won't connect. I also tried removing the Sensor and reinstalling it, and it won't connect to the Nest Thermostat (3rd Gen).
02-13-2024 07:56 AM
Hello Ycmford,
Thank you for reaching out and bringing to our attention the connectivity issue you are experiencing with your Nest Temperature Sensor after installing the Nest Connect for your Yale lock.
Let's troubleshoot this together.
I hope this helps, and your Nest devices get back to working seamlessly together.
02-26-2024 03:50 PM
Hello Markjosephp, what you said is in the Nest Thermostat itself, no in the app? is this true?
02-27-2024 07:53 AM
Hi jcmarianacci,
Thanks for stopping by. Yes, the Nest Thermostat device itself. The Nest Temperature Sensor relies on the thermostat's connectivity. If it happens that it drops its network connection, the sensor will disconnect as well. So if the sensor still doesn't reconnect after a series of steps, restarting or resetting the thermostat's Account Connection would help.
Let me know if you have more questions.
02-27-2024 09:37 AM
Hello! I wound up uninstalling and reinstalling the Nest Thermostat, then installing the Nest Sensor and it worked. As an aside, I've had so many issues with everything since I installed Nest Connect (now my cameras are acting up!). I'll try uninstalling and reinstalling them to the app as well.
02-28-2024 01:59 PM
Awesome! I'm glad to hear that reinstalling the Nest Thermostat and adding the Nest Temperature Sensor resolved your initial issue. It's unfortunate to hear about the troubles with Nest Connect causing problems with your cameras. Reinstalling them on the app might indeed help stabilize their performance. If the issues persist, let us know so we can further check them as well.
