02-19-2024 11:35 AM
Furnace loses thermostat heat signal intermittently during startup and chatters the gas valve and auxiliary combustion air intake system. Furnace often then fails to fire and then short cycles to recover. C wire is installed. Single zone gas hot air heat and AC.
02-23-2024 07:24 AM
Hi pjmcgnns,
Thanks for posting here in the Google Nest Community forum.
We're sorry for any trouble this may have caused you. I wanted to check this further for you. Let’s gather the power reading of your Nest Thermostat.
For the Nest Learning Thermostat and Nest Thermostat E:
For the Nest Thermostat 2020:
Also, send us a couple more details, like the make and model of your HVAC, a photo of your current wiring on the Nest Thermostat, and the wiring on the control board.
Renz
02-23-2024 07:26 AM
Power is 3.78volts. Heater Controller Conquest 90 high efficiency gas hot air furnace 1 stage. How do I add pictures of the wiring?
02-28-2024 11:09 AM
Hello pjmcgnns,
Thanks for the update. Have you also gotten the VOC, VIN, and LIN details when you run the power reading? To attach the image, you can go to this link: Google Nest Community Forum. Hit reply on the thread, and you'll see a camera icon or three horizontal lines to expand the toolbar, where you can click the camera icon and send your image.
Keep us posted.
Renz
02-28-2024 03:20 PM
There is no camera icon when I expand the 3 dots
Battery:3.931
VOC:36.95
VIN:36.95
LIN:200 ma (c)
