07-19-2022 07:36 AM
I have for four temp sensors. The Nest app says my temp sensor has a low battery, but doesn't tell me which one. Nor do I find a battery status indicator for my temp sensors in the app. How do I tell which sensor has the low battery? Process of elimination? Thanks.
07-25-2022 12:22 PM
I was able to click on the wheel icon for the thermostat and then scroll down to sensors. Hit the sensor you’d like and scroll down under the sensor information to technical info. Then you’ll see battery life which is odd because all of my sensors say battery life ok.
07-25-2022 12:14 PM
I’m following. Mine says the same thing. Quite frustrating. I don’t want to do process of elimination. It should be able to tell us which sensor is low, especially since we name the sensors. Please let me know if you find away if distinguishing which one. I’ll do the same. Thank you!
07-25-2022 12:22 PM
07-25-2022 08:44 PM
Great find. I thought I checked everywhere, but I obviously didn't. Thanks so much!
07-26-2022 01:55 PM
Hey there 7198603,
I'm glad to hear that BrandiC8 was able to help you out! In the meantime, did you have any more questions or need any additional help?
Thank you,
Jeran
07-26-2022 03:36 PM
Nope. That's it. Thanks for following up, Jeran.
07-28-2022 10:43 AM
Hiya 7198603,
Of course! In that case, I'll go ahead and lock this thread. If you run into any more issues in the future, please feel free to create a new thread.
Thank you for your help on this, BrandiC8!
Jeran
