Nest Temperature not Reading Right and Farsight not Working
vgleason
I have the 3rd Generation Nest Learning Thermostat. My Nest is reading it is 72 degrees F however my thermometer reads 69 degrees F. I also have been trying to change the display on the Farsight and nothing changes when I select current temp vs target temp vs analog etc.
Please advise on both situations
zoeuvre
Thanks for posting here in the Community and I’m sorry for the late reply. Please give us your Nest Learning Thermostat's current signal strength by following the procedures listed below.
  1. To open the Quick View menu, press the thermostat’s ring.
  2. Choose Settings.
  3. Turn the ring to highlight Technical Info then press the ring to select it.
  4. Get the Signal strength value.
On the other hand, try to disable and enable your Nest Learning Thermostat's farsight feature.
Princesss
Hello vgleason,
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
Princesss
Hello there,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest devices and we'd be glad to assist you further.
Princess
