Nest Thermostat Not Cooling Fast
MHUD220
Using my AC for the first time since installing the nest thermostat and my home is cooling...just not quick enough. It seems to be constantly running and says it will reach set temperature in 1 hour (76 degrees set to 72).  Was curious if it just needs to learn how my home cools or if it may be another issue. (It is not a learning nest)
All thermostats including the Nest are just a fancy on/off switch. What controls how fast your system heats or cools is the HVAC system itself.
Check to see if the blower is operating correctly, that the filter isn't clogged, and when was the last time did you have your system serviced?
Ryan_G
Hi MHUD220,
Thanks for reaching out here in the community.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. If you need further assistance, let us know by replying to this thread.
Thank you for helping us, Patrick_Caezza.
Ryan
Ryan_G
Hey MHUD220,
Ryan
Ryan_G
Have a great day.
Ryan
