Nest Thermostat Upstairs heat isn’t getting consistent power
Bmorn20
i have the power connector hooked up by i constantly get the n271 error. has anyone seen this issue. after about a year of with the power connector hooked to a brand new boiler install, my relay shorted out and i dont know if any of this is related. my downstairs therm does works perfectly fine without the C wire our the power connector.
EdwardT
Hi Bmorn20,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. Could you share a photo of the exact message that you're getting?
Edward
EdwardT
Hey Bmorn20,
Edward
EdwardT
Hi Bmorn20,
Edward
Bmorn20
hello
you can close, i am having a C wire ran to the unit and removing the power connector.
EdwardT
Hi Bmorn20,
Thanks for the update. I will be locking this thread now. Feel free to submit another post, and provide as many details as possible so that others can lend a hand.
Edward
