09-30-2021 03:08 PM
I've had 3 different Nest Thermostat units. All of them work fine out of the box and connect to the wifi with no problem. They've all worked fine for some amount of time and then randomly lose their connection to my wifi. They won't reconnect or even find my wifi network. The Nest is the ONLY device (out of dozens) in my house that won't stay connected to the wifi. There are several articles online outlining this issue. Each time, I contact Nest support and they walk me through a series of checks / procedures - standard things like restart the nest, reset the nest, restart the router, remove and re-add the device on the app, check wifi / router settings, etc. - all basic stuff, none of which fixes the issue. Their only response is to send me another thermostat. After dealing with this for over a year and several replacement devices, I asked them to instead issue me a refund, which they won't do. So today, I now have my 4th replacement on the way. I can't believe there is no refund policy after all of this. 4th times a charm, Google?
10-28-2021 02:05 PM
Hey buckjw,
I am sorry for the delayed response. I wanted to follow up and ensure you are good to go. Please let me know if you are still having trouble with the device connecting to the Wi-Fi, as I would be happy to take a closer look and assist you further.
11-02-2021 11:09 AM
Hey buckjw,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
11-02-2021 11:27 AM
Yes, I'm good. I have a replacement which is working (for now).
11-02-2021 11:53 AM
Hey buckjw,
Glad to hear you were able to get the issue resolved. With that being the case, I will be locking the thread at this time. If you run into any questions from here, please feel free to create a new post.
