Nest Thermostat Wire Help
Krysaurus
Hi!
I've installed a nest thermostat before in my old apartment but it was pretty much the basic wires (Y, C, G, R and W) that lined up to the Nest Thermostat. Moved into a new home and my Honeywell thermostat has these wires. Google says the Nest Thermostat is compatible but I was wondering where would the wires go? Specifically the red R and the dark blue Rc that is connected to R as well.
If the nest thermostat isn't compatible is the Nest Learning Thermostat compatible and where would the R, and Rc go?
Unable to upload image but here's the image below
https://ibb.co/DtzzPnz
thanks in advanced 🙂
zoeuvre
Hi Krysaurus,
Thanks for posting here in the Community forum and for showing interest in our Nest Thermostats. Fortunately, your thermostat wires are compatible with any of our Nest Thermostat and should be wired to the Nest Thermostat base as follows:
  • Yellow wire to Y or Y1
  • Green wire to G
  • Red wire to R or RC or RH
  • White wire to W1
  • Blue wire to C
You don't have to install the blue jumper wire from RC to R to the Nest Thermostat base, as that is not needed. Also, here's a guide for the installation and setup of a Nest Thermostat
Let us know if that helps.
