11-21-2022 05:02 AM - edited 11-21-2022 05:03 AM
Google nest thermostat installed with new heat pump “turns on heat” (registers as “heating”), but the temperature drops ten degrees at night while “heat” is on. There are two additional Alt Heat stages which work perfectly when testing and troubleshooting. The heating tech was just out three days ago and replaced the capacitor and reversing valve.
How can we force Nest to engage alternate heat when the temperature falls? I get notifications from nest that something may be wrong, but it’s clearly an issue with the thresholds of the nest software and not the mechanical side.
11-25-2022 06:40 PM
Hi mzc0789,
Thanks for reaching out. I'm sorry to hear that you're having an issue with the heating of your Nest Thermostat. I'd love to know more about this and I have a few questions:
You can also click on this link for some troubleshooting steps you could try.
Edward
11-28-2022 09:30 PM
I appreciate the help, Edward.
Archie
11-30-2022 04:05 PM
Archie
