11-03-2022 11:49 PM
I have a u shaped connector to the board and am not sure how to disconnect it so I can rewire it. Please see attached picture.
11-08-2022 12:19 PM
Hello NestThermostat,
Thank you for taking the time in letting us know about your inquiry. I'd be happy to take a look into this for you.
Based on the pictures, It appears that it's the wiring configuration from your system's control panel. Usually, there's no need to re-wire it unless you're asked to or if your system isn't compatible with the Nest. To be sure, would you mind sending us a picture of your thermostat wiring setup?
Marm
11-11-2022 12:27 PM
11-12-2022 12:40 PM
Hi NestThermostat,
I want to check if you have seen my response posted above. Let us know if you have additional questions, otherwise we'll be locking the thread in 24 hours.
