01-12-2023 12:24 PM
I have run into a connectivity issue on my Nest Thermostat. It has run problem free for just under two years. A few days ago it went offline and informed me it could not find the network. It shows the following product information. Model Display 3.7 running software version 6.2-27, Backplate Model 5.26 showing software version 2.3.51/3.1.
Steps taken
My suspicion is that the WIFI is no longer working on the thermostat. That being the case, I'm not sure where to go from here, so I'm looking for suggestions.
This is the second nest thermostat I have owned the first one I had at another home for over ten years with no problems but that was pre-Google. I currently am running both the original (at another home) and my new one on the Nest app. Until I sell my other house I am holding off switching to running my new one off of Google home. My current one continues to operate as a thermostat, but at the price I paid I expected it to last more than a couple of years.
01-17-2023 10:23 AM
Hello JoHo,
I'm sorry to hear that you're having issues reconnecting your thermostat to your Wi-Fi network, and I appreciate all the steps you've taken. I'd be happy to take a look into this for you.
To isolate:
Additional steps:
Please let me know if that helps, or if the issue still persists.
01-20-2023 11:26 AM
Hello everyone,
@JoHo how's it going with your Nest Thermostat? We would appreciate it if you could share with us the information we're asking above. Also, were you able to perform the steps suggested above? We'd be glad to hear from you — We'd like to make sure everything is working.
I appreciate the help, Mark.
01-20-2023 01:42 PM
Mark,
I had done all of the things you suggested before I sent my email based on prior responses. I have received no error codes. Reset the thermostat, did as you suggested. No error codes, both times. I can see where it dropped of the network on my router around 10 a.m. January 10th. I'm pretty sure the Wi-Fi chip failed.
John
01-20-2023 02:58 PM
Hi JoHo,
Thanks for getting back to us and for sharing with us what you've done. To confirm, have you tried restarting your Wi-Fi network? To further isolate this issue, try connecting your Nest Thermostat using a mobile hotspot and create a new home structure and add the Nest Thermostat there.
Let us know how it goes.
01-24-2023 09:37 AM
Hello JoHo,
How's it going with your Nest Thermostat? We would appreciate it if you could share with us the information I’m asking above. Also, were you able to perform the steps I’m suggesting? We'd be glad to hear from you — We'd like to make sure everything is working.
01-25-2023 11:11 AM
Hey JoHo,
