02-08-2024 01:49 PM
We had an hvac technician out recently to service our system and we discussed switching out our current thermostat to a Nest. The technician seemed confident Nest would work, but when I went to order one the Google Nest compatibility checker said it would not work. I contacted Google support and the support person said it wouldn't work but he had no idea why.
We have the following wires hooked up in our current thermostat: Y1, W2, G, RC, C, O, B (there is also one black wire that is not hooked to anything, and there is one jumper from RH to RC). Printed inside the thermostat cover there is a guide that identifies each wire. The guide says: RC = 24VAC Power Supply, C = 24VAC Common, Y1 = Compressor Stage 1, W2 = Auxilliary heat, O = Cool mode powered reverse valve, B = Heat mode powered reverse valve, G = Fan.
Any HVAC pros have an idea why Google thinks this won't work for us?
02-08-2024 07:58 PM
@DJMarsh , your heat pump is either an O model or it is a B model. There cannot be both a B and an O for the same heat pump. Since you have a C terminal you need to further investigate to see what type you have. Now then, O models are heaters by default, and the thermostat must energize the O to switch it to Cooling mode. The opposite is true for B models. The B models are Air Conditioner by default, and the thermostat must energize the B wire to switch the heat pump into Heating mode.
How to test what model you have. DO NOT PERFORM THIS TEST IF THE OUTDOOR AIR TEMPERATURE IS BELOW 70°F. On your thermostat remove the B wire and remove the O from the terminal connector. Then turn on the Heating and see if the air blows out ice cold or warm. If ice cold, you have a B model. If Warm are comes out, you have an O model.
AC Cooling Wizard
02-08-2024 07:58 PM
AC Cooling Wizard
