03-01-2022 07:07 AM
Hi
I currently have an oil fired boiler. I am thinking about putting in a Nest Learning Thermostat. I think I will probably install an air source heat pump at some point in the future. Will my Nest be able to work with the heat pump in the future? What if I end up keeping the oil boiler (rather than replacing it) so it can augment the heat pump when needed?
Thanks for any input
David
03-07-2022 08:03 PM
Hey digger,
Thanks for reaching out and sorry for the delayed response.
Yes, you may still use your Nest thermostat if you will be changing to a heat pump system. Just make sure that your heat pump is compatible by checking our compatibility checker here: https://bit.ly/3qZ6OQ1
Melba
03-08-2022 03:26 AM
Thanks very much for your help!
regards
david
03-08-2022 02:37 PM
You're welcome — let me know if there's anything else.
Melba
03-11-2022 05:06 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
