11-29-2023 06:29 PM
I have a nest thermostat and no c wire, but there are extra unused wires available. Can I simply get a plug-in transformer and attach it to the nest to give it the power it needs? Or is there more that I need to do to control the system? Thanks
12-03-2023 02:39 PM
Hi Jdorow,
Thanks for checking it with us. A few questions: what type of Nest Thermostat do you have? In what country are you located? How much power (V) did that extra wire have? You can use a voltmeter to check it. Do you have a voltmeter? If yes, are you comfortable using it?
Voltmeters and multimeters come in two types, analog and digital.
Analog models are no longer common, but they can still be found. They have a needle that moves across a window similar to a speedometer on a car.
Digital models give a specific readout of the exact voltage measured. They can be extremely accurate and helpful for measuring voltage.
When using a voltmeter you should turn the dial or switch to AC. AC current allows voltage to flow through the leads and allows the voltmeter to display an accurate readout.
To check voltage over any R wire: If your breakers are off, you will need to turn them on. On most multimeters, AC current is designated by VAC or V~.
Follow this guide:
Please keep me posted.
11-29-2023 06:27 PM
12-03-2023 02:50 PM - edited 12-03-2023 04:01 PM
Hi Jdorow,
Looks like your post matched an existing conversation. To keep our community organized and easy to browse, we’ve merged your post with your original thread.
